911 oil temp / pressure gauge, how did you mount the pressure sensor? |
falcor75 |
May 24 2018, 11:01 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I installed a 911 oil temp and pressure gauge this Winter.
I didnt want to hack up my engine tins to mount the sensor in the stock location so I made bracket and mounted it on the fan housing where the stock coil sits and connected it to the oil pressure port with a piece of steel braided hose with the correct end fittings. It works well and doesnt leak but I've noticed that in long sweeping left hand turns I loose oil pressure, it never goes to zero but once or twice the light flickered on and then immediatly turned off again. Do you think this could be a sensor location thing or perhaps an issue with my tuna can installation? |
falcor75 |
May 27 2018, 09:44 AM
Yes I've already started investingating an accusump setup in case I cant find the problem. Do you have any pictures of your setup installed. It would be interesting to see.
Lo-Fi Version | Time is now: 20th April 2024 - 09:46 AM |
