911 oil temp / pressure gauge, how did you mount the pressure sensor? |
falcor75 |
May 24 2018, 11:01 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I installed a 911 oil temp and pressure gauge this Winter.
I didnt want to hack up my engine tins to mount the sensor in the stock location so I made bracket and mounted it on the fan housing where the stock coil sits and connected it to the oil pressure port with a piece of steel braided hose with the correct end fittings. It works well and doesnt leak but I've noticed that in long sweeping left hand turns I loose oil pressure, it never goes to zero but once or twice the light flickered on and then immediatly turned off again. Do you think this could be a sensor location thing or perhaps an issue with my tuna can installation? |
falcor75 |
Jun 8 2018, 02:19 PM
Tuna can remounted, overfilled with about half a quart/litre over max on the dipstick. Ive also plugged the head vents with some silicone rubber hats. The connector on the oil filler tower is routed thru a half inch hose to a catch can thats then vented directly to the athmosphere thru a filter. Havnt driven it much yet but at least it doesnt loose oil pressure in roundabouts anymore from what I can tell.
Lo-Fi Version | Time is now: 25th April 2024 - 10:42 PM |
