911 oil temp / pressure gauge, how did you mount the pressure sensor? |
falcor75 |
May 24 2018, 11:01 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I installed a 911 oil temp and pressure gauge this Winter.
I didnt want to hack up my engine tins to mount the sensor in the stock location so I made bracket and mounted it on the fan housing where the stock coil sits and connected it to the oil pressure port with a piece of steel braided hose with the correct end fittings. It works well and doesnt leak but I've noticed that in long sweeping left hand turns I loose oil pressure, it never goes to zero but once or twice the light flickered on and then immediatly turned off again. Do you think this could be a sensor location thing or perhaps an issue with my tuna can installation? |
Frank S |
Jun 12 2018, 10:57 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Hi Mats,
I've used following adaptor: http://www.ezt-autoteile.de/VDO-Sensoren...15::264924.html The adaptor need to be blanked off at the side port (M10x1) at the top its a ATE M10x1 Banjo fitting mounted with a M12x1,5 Banjo Bolt. If I have a chance, I'll send a better pic next weekend. |
Lo-Fi Version | Time is now: 19th April 2024 - 06:47 PM |
