Shifter Linkage Upgrade |
Montreal914 |
May 27 2018, 03:35 PM
Senior Member Group: Members Posts: 1,562 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
When I first saw the JWest shift linkage upgrade (NLA), I though it was a very elegant way to handle the support of the ball sleeve mechanism in the side shift gearbox console. I assume cost was the reason Porsche didn't do it that way.
I've always wanted to do something similar (IMG:style_emoticons/default/stirthepot.gif) . Being on a budget, I decided to modify/fabricated all of the components myself but pretty much all of this upgrade can be done with parts available through our member vendors here in one form or another. Here we go! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving.gif) Shift Console Preparation All of this started when I got a spare gearbox with a broken shift console. I though this was the perfect candidate to play with since it can't be used in its current form. I cut the remaining part of the bushing tab and file the casting flush. Then I prepared what would be the two new supporting tabs in which there would be oil impregnated bronze bushings. These tabs are made from a 1 1/4" x 3/8" aluminum flat bar. The 7/8" hole was machined in the right location (center 15mm from the console reference surface) to maintain the stock position of the shift rod. The bronze bushings (McMaster Carr 6338K426) were grooved to accept a snap ring (McMaster Carr 98585A115) to secure them to the tabs. Using a piece of 5/8" shaft, I do the first layout of the assembly. Then, with a file (aluminum is a beautiful material), I did the weld preparation of the various surfaces as per recommendations from my welder. Then my welder did his magic while taking his time and extra care to make sure the material didn't pull which would have resulted with bent tabs where bushings wouldn't have lined up and ruined the whole thing. Yes the preferred way of doing this would have been to weld first and machine after but that would have made the machining of the tabs more expensive due to an elaborate setup to hold the console. I would probably do it this way if I was doing it again, but since I had a good welder, he pulled it off nicely (IMG:style_emoticons/default/sunglasses.gif) Then I used my trusted hack saw and files to smooth it out and bring it to a shape that could ressemble somewhat a stock casting form. (IMG:style_emoticons/default/w00t.gif) Last, I reassembled the rest of the components with a fresh seal and the console assembly was ready to be installed on the gearbox. (IMG:style_emoticons/default/beer3.gif) |
maf914 |
May 29 2018, 07:15 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Excellent thread, Montreal914. Thanks for posting.
How are the results? How does it shift? We need details! (IMG:style_emoticons/default/laugh.gif) |
Montreal914 |
May 29 2018, 01:35 PM
Excellent thread, Montreal914. Thanks for posting. How are the results? How does it shift? We need details! (IMG:style_emoticons/default/laugh.gif) It shifts very nice and smooth. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/driving.gif) I'm very happy with it. Actually, it's so easy to move that the spring plate in the stock shifter that you press to be in the R-1 plane actually pushes the lever to the 4-5 plane when disengaging from 1st. I have to "catch it" to place it in the 2-3 plane when going from 1st to 2nd. This means I need something spring loaded on both sides like the Rennshift to keep the lever nominal in the 2-3 plane. More thinking ahead (IMG:style_emoticons/default/stirthepot.gif) |
porschetub |
May 29 2018, 11:50 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Excellent thread, Montreal914. Thanks for posting. How are the results? How does it shift? We need details! (IMG:style_emoticons/default/laugh.gif) It shifts very nice and smooth. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/driving.gif) I'm very happy with it. Actually, it's so easy to move that the spring plate in the stock shifter that you press to be in the R-1 plane actually pushes the lever to the 4-5 plane when disengaging from 1st. I have to "catch it" to place it in the 2-3 plane when going from 1st to 2nd. This means I need something spring loaded on both sides like the Rennshift to keep the lever nominal in the 2-3 plane. More thinking ahead (IMG:style_emoticons/default/stirthepot.gif) Wow great skills,love to have all that machinery so envious,hope it all works for out well .....should be cause you have done a great job (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) . |
Lo-Fi Version | Time is now: 20th May 2024 - 06:21 PM |
