Bad Gauge?, Or is it an electrical gremlin? |
stevend914 |
May 29 2018, 07:20 AM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
The voltage gauge is showing just over 12 volts but the voltmeter is showing 13.5. Could the gauge be faulty?
76-914 |
May 29 2018, 07:28 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Normal. If you run a dedicated wire from the battery to the Gauge it will be the same reading.
914Sixer |
May 29 2018, 07:30 AM
Don't worry, your gauge is about as accurate as it is going to get. Not made with the performance of today's gauges. Remember these were cheap cars.
stevend914 |
May 29 2018, 07:38 AM
OK, thanks to you both (IMG:style_emoticons/default/smile.gif)
porschetub |
May 30 2018, 03:49 PM
Have the same issue with a new VDO volt meter,I have a separate Hella fuse box I put in for any extra's,plan to wire the gauge direct to there. I checked the gauge and its fine off a battery, appears to be reading 1.2 volts low. I'am wired to the original centre console loom, guess the wiring too light and old to carry all the current. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:20 PM |
