GT style cockpit oil line cover. |
mb911 |
May 31 2018, 09:11 AM
914 Guru Group: Members Posts: 6,748 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
mmascari |
May 31 2018, 09:27 AM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
That is great! I will buy one.
Attached thumbnail(s) |
11tenths |
May 31 2018, 09:34 AM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
mb911 |
May 31 2018, 01:11 PM
I thought about that as well.. What would we want that to look like though?
Martin Baker |
May 31 2018, 01:36 PM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
I will buy two if they resemble what the factory did...
mb911 |
May 31 2018, 02:21 PM
mlindner |
May 31 2018, 03:39 PM
Senior Member Group: Members Posts: 1,496 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
God Ben, you just keep coming up with neat stuff, love it. Mark
porschetub |
May 31 2018, 03:56 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
May 31 2018, 05:45 PM
Custom Member Group: Members Posts: 24,501 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I was thinking the same thing. Might want to consider a double walled version to make sure you don't get burned. Also so fresh air ducted through that new cavity. |
May 31 2018, 06:04 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I was thinking the same thing. Might want to consider a double walled version to make sure you don't get burned. Also so fresh air ducted through that new cavity. I think you all are trying to make this more complicated than it needs to be. If the metal does get hot, just add some heat wrap to the outside and maybe inside or wrap the lines, or both. The heat wrap that is used for exhaust is cheap and effective. 16’ of 2” exhaust wrap - $10 at walmart https://www.walmart.com/ip/Yescom-2-16-4ft-...13=&veh=sem Attached image(s) |
Norskpole |
May 31 2018, 06:12 PM
Member Group: Members Posts: 60 Joined: 18-April 10 From: Oceanside, CA Member No.: 11,628 Region Association: Southern California |
I'd be interested in one, if you go ahead with it (IMG:style_emoticons/default/popcorn[1].gif)
Steve |
May 31 2018, 06:16 PM
914 Guru Group: Members Posts: 5,548 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
It looks kind of big. If it was more form fitting I would be in for one. It would help keep dirt out. I have the heat blanket around my lines now from PMS.
live free & drive |
Jun 1 2018, 05:54 AM
Member Group: Members Posts: 154 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
I'd be in for one, but like Steve says it would be nice if it were a bit more form fitting.
Larmo63 |
Jun 1 2018, 06:34 AM
Both of my AN oil lines feed into one big heat shield sock as they go through the passenger compartment footwell.
I've never felt any real heat from that area. I'd be interested in this if you perfect it, but an exterior shield for road grime and water would be another part idea (?) |
mb911 |
Jun 1 2018, 06:41 AM
I know it looks big but it actually is pretty small compared to what I started with. Its only 2.5" thick all the way around the radius of the inner wheel well and 4" tall.. Form fitting is the interesting thing as the lines stack on top of eachother and are about 1.5" in diameter it allows for some heat wrap as you say.. I may shrink it a bit more but the bump out that it bolts to is about 2.5" as well..
Steve |
Jun 1 2018, 06:46 AM
Thanks Ben!! It’s probably just the picture. Showing one installed would be better. I would also be interested in one.
davehg |
Jun 1 2018, 07:43 AM
Member Group: Members Posts: 180 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
Add me to the interested list!
dr914@autoatlanta.com |
Jun 1 2018, 08:42 AM
914 Guru Group: Members Posts: 7,772 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Shoot, sorry Ben, should have thought of you when we had to fabricate one for Brutus the 916 (now in the Peterson Museum in LA)
Anyway we took the one out of our 916 and copied it. It looks MUCH different than the one you made, and maybe we could arrange something so that you could copy the original. It also has a built in pedal board clamp! |
mb911 |
Jun 1 2018, 09:02 AM
Shoot, sorry Ben, should have thought of you when we had to fabricate one for Brutus the 916 (now in the Peterson Museum in LA) Anyway we took the one out of our 916 and copied it. It looks MUCH different than the one you made, and maybe we could arrange something so that you could copy the original. It also has a built in pedal board clamp! I am not 100% sold on this yet but I know I need a protective cover for the GT oil lines. Thought I would share That would be really cool.. |
Cairo94507 |
Jun 1 2018, 09:23 AM
Michael Group: Members Posts: 9,650 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I am pretty sure Kent is either working on or soon to be working on one of these for my car. I definitely want the lines covered and protected as well as sealing the exterior from the interior where the lines enter the cabin. (IMG:style_emoticons/default/beer3.gif)
Lo-Fi Version | Time is now: 28th March 2024 - 10:52 PM |
