Hesitation/miss at steady throttle |
nsargeant |
Jun 3 2018, 05:06 PM
Newbie Group: Members Posts: 12 Joined: 27-August 17 From: Vincennes, In Member No.: 21,381 Region Association: Upper MidWest |
I have a 1974 914 2.0 that I purchased last summer. When I bought it the connector to the TPS was unhooked. It seemed to run a bit rich and load up a little right after starting but outside of that,seemed to run ok without any hesitations. After i fixed a couple wires and hooked it up it ran better. Better throttle response, better starts, and even seems a little quicker. It seems after it warms up though i will get a miss occasionally while at a steady throttle. As soon as i accelerate when it is missing it comes out of it. It will probably miss/hesitate a few times in a 10 mile drive. Seems to happen in between 3-4000 rpm. Is this a common problem with a TPS going out? am I even looking in the right direction? It doesn't seem to do it when the plug is unhooked from the tps.
Thanks, Nathan |
Lo-Fi Version | Time is now: 16th May 2024 - 03:17 AM |
