Frustrations, Part Seller |
914Sixer |
Jun 4 2018, 03:57 PM
914 Guru Group: Members Posts: 8,869 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
As you know I am looking for a passenger 914-4 Bilstein strut. Mark E suggested I call DC Automotive. So I did. Well the seller on the other end of the line told me he had been doing it for 25 years and that he had never heard of such a thing. I assured him that I had two drivers sides and that they were real and they had a 3" brake caliper pattern. Seller was again polite but indicated I was nuts. I said thank you and went on. (IMG:style_emoticons/default/confused24.gif)
I found it amusing. I hope that I am able to learn something new everyday. Still working on being a know it all after all these years. (IMG:style_emoticons/default/popcorn[1].gif) |
Chris914n6 |
Jun 4 2018, 05:02 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
914s only came with Boge struts. I believe Bilsteins were optional on 911s or part of the race program (still 5 lug).
Have you fitted a hub and caliper on it? |
Jun 4 2018, 05:53 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I thought you could get a billstein insert as an option but I’ve never seen a billstein 914-4 strut.
Rob is a good guy. His first Porsche was a 914 with a Mitcom body kit. He just sold it to one of his employees. Unfortunately, he no longer carries many 914 parts. Out of 140,000 sq/ft (not a typo) only about 400 sq/ft are 914. |
JeffBowlsby |
Jun 4 2018, 06:17 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Bilstein struts were an available 914/4 option. I have a set, special PN.
Jun 4 2018, 06:18 PM
JeffBowlsby |
Jun 4 2018, 06:32 PM
914 341 091 34
914 341 092 34 Mine need to be stripped and repainted. Attached thumbnail(s) |
914Sixer |
Jun 4 2018, 06:43 PM
There is a set for sale in the classified section. Added pictures from classifieds. Mine are over in the warehouse.
Jun 4 2018, 06:45 PM
914werke |
Jun 4 2018, 07:00 PM
"I got blisters on me fingers" Group: Members Posts: 9,999 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
as do I (IMG:style_emoticons/default/smile.gif)
Still looking for a source for the seals & hw to rebuild otherwise Id put them back on the LE. Jeff could confirm but I thought there was an actual option pkg/code from Porsche. Attached image(s) |
914Sixer |
Jun 4 2018, 07:04 PM
You can use 911 inserts.
914werke |
Jun 4 2018, 07:07 PM
Mark to your orig theme, I had a similar experience recently talking to FAT.
Made contact re sourcing someone to do the dual plug machining for my next build And spoke with some yahoo who claimed they'd never done it never heard of it outside of light aircraft and couldn't understand why ..."seems like a total waste of money" |
Jun 4 2018, 07:17 PM
Mark to your orig theme, I had a similar experience recently talking to FAT. Made contact re sourcing someone to do the dual plug machining for my next build And spoke with some yahoo who claimed they'd never done it never heard of it outside of light aircraft and couldn't understand why ..."seems like a total waste of money" My 2004 Dodge Durango has dual plugs. |
Jun 4 2018, 07:28 PM
Custom Member Group: Members Posts: 24,562 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Have you tried Brad in Illinois, or Rick at HPH in the Bay Area?
Mark Henry |
Jun 5 2018, 06:59 AM
914 341 091 34 914 341 092 34 Mine need to be stripped and repainted. The bearing surface on the spindle may be too far gone unless that is just light surface rust. You can get them chromed (not the pretty chrome) or use a Speedi-sleeve. A crank machine shop should be able to do this. |
JeffBowlsby |
Jun 5 2018, 09:30 AM
its just light surface corrosion. A brillo pad will take it off.
Contact/send them to Bilstein directly...in SoCal if I recall...they will rebuild them. |
rhodyguy |
Jun 5 2018, 03:17 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
There's a well optioned 2.0 75' up here with green units on all 4 corners. 'Option' on the window sticker. Cool car.
mtndawg |
Jun 5 2018, 03:42 PM
Member Group: Members Posts: 413 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
davep |
Jun 23 2018, 05:28 AM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I have a set on my LE, but not sure that they are original since the rears are yellow. Also have a spare set of Bilstein's awaiting a project. I understand that factory installed rear Bilstein are green.
914Sixer |
Jun 23 2018, 05:47 AM
The original factory rears were green.
JeffBowlsby |
Jun 23 2018, 09:04 AM
Lo-Fi Version | Time is now: 25th April 2024 - 04:27 AM |
