Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 5 2018, 12:18 AM
Moving onto the engine compartment. The top of my long in the hellhole has some holes and needs to be patched. Battery tray comes out too.
I got a shrinker and stretcher tool from HF, along with a cheap-o bending brake. I was able to make the hellhole patch out of 18g steel. I cut out the offending metal and a piece of the lower firewall. I had to also cut a 2x8 inch patch on the side wall. When welding in the side wall patch the quarter panel pulled tight getting rid of a weird pucker at the leading edge of the rear quarter panel. Quite a bonus and reminder that I need to slow it down. For the hell hole patch, i spread the welding out over a few days. No shrinking here and looks pretty good. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 6th May 2024 - 12:35 AM |
