Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 12 2018, 11:45 PM
Thanks Bryan! Good to see you (IMG:style_emoticons/default/beerchug.gif)
I found my floor has a slope side to side at about 3/8 of an inch. If I use some left over 3/8 bamboo flooring on the drivers side it gets me level side to side. For the back I used a couple 4x4 screwed together and then screwed the ramp stands to it in the back. I dont have any more ramp stands for the front, so I used jack stands at the forward lift points and then a single jack stand at the front trunk floor. Its mostly level, I need to drop the drivers side rear coilover a 1/4 of an inch or so. I will do that tomorrow. What do you all think? Attached thumbnail(s) |
rick 918-S |
Jun 13 2018, 05:22 AM
Hey nice rack! -Celette Group: Members Posts: 20,427 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Thanks Bryan! Good to see you (IMG:style_emoticons/default/beerchug.gif) I found my floor has a slope side to side at about 3/8 of an inch. If I use some left over 3/8 bamboo flooring on the drivers side it gets me level side to side. For the back I used a couple 4x4 screwed together and then screwed the ramp stands to it in the back. I dont have any more ramp stands for the front, so I used jack stands at the forward lift points and then a single jack stand at the front trunk floor. Its mostly level, I need to drop the drivers side rear coilover a 1/4 of an inch or so. I will do that tomorrow. What do you all think? (IMG:style_emoticons/default/agree.gif) that should work (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 1st May 2024 - 05:32 AM |
