Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
djb |
Jun 13 2018, 10:10 PM
Newbie Group: Members Posts: 7 Joined: 2-November 17 From: El Dorado Member No.: 21,566 Region Association: Northern California |
Really great thread!
Consider using a water level to make sure your chassis is perfectly level before you start cutting things. Super easy to do and you will be guaranteed dead nuts on. https://www.wikihow.com/Use-a-Water-Level David |
TravisNeff |
Jun 13 2018, 10:40 PM
Really great thread! Consider using a water level to make sure your chassis is perfectly level before you start cutting things. Super easy to do and you will be guaranteed dead nuts on. https://www.wikihow.com/Use-a-Water-Level David Oooh! I will give that a shot, thank you! |
Lo-Fi Version | Time is now: 6th May 2024 - 02:14 PM |
