Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 14 2018, 03:06 PM
Thanks for the vote of confidence Larmo!
OK, I need to get something done today and the new jack stands wont arrive until saturday sometime. Did a tire stack and then a couple sections of leftover wood countertop, and a couple of 2x4's to bridge the gap. Then got to work and finished cutting out that damn engine mount on the drivers side. What a bitch! I have just a little bit of cleanup and wire wheel it clean and I can call it good enough. Attached image(s) |
mb911 |
Jun 14 2018, 04:03 PM
914 Guru Group: Members Posts: 6,822 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Thanks for the vote of confidence Larmo! OK, I need to get something done today and the new jack stands wont arrive until saturday sometime. Did a tire stack and then a couple sections of leftover wood countertop, and a couple of 2x4's to bridge the gap. Then got to work and finished cutting out that damn engine mount on the drivers side. What a bitch! I have just a little bit of cleanup and wire wheel it clean and I can call it good enough. That is for sure they are a PIA to remove.. |
Lo-Fi Version | Time is now: 4th May 2024 - 10:23 AM |
