Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 18 2018, 07:51 PM
Alright, I will get both sizes and some flat bar stock to create the recesses. (IMG:style_emoticons/default/smash.gif)
Scrubbed things down a bit more with a smaller sized wire brush I found, then hosed it down with Metal Prep. That stuff has some STANK. |
bbrock |
Jun 18 2018, 08:16 PM
Alright, I will get both sizes and some flat bar stock to create the recesses. (IMG:style_emoticons/default/smash.gif) Scrubbed things down a bit more with a smaller sized wire brush I found, then hosed it down with Metal Prep. That stuff has some STANK. Oh yeah, on the recesses, I made my forms as positives that I hammered what would be recesses on the panel over the bar stock which worked, but is the stupid way unless you really want to work on your upper arm strength. Check out Ben's (mb911) thread for a better way to do it which is to hammer the recesses DOWN into recesses in your forms. (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 26th May 2024 - 03:17 PM |
