Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 4 2018, 11:51 PM
Here's the engine. It is a 1974 2.7 engine (non S) with Weber carbs from one of our world members. It supposedly had a recent top end rebuild. I used one of those little cameras on a cord so I can peek down the plug holes, it has CIS pistons. I imagine this is all stock except for the carbs.
I have taken apart the carbs and cleaned it all up. I also put in a 123 distributor that I purchased from another world member. I pulled the chainbox cover and found that this engine has mechanical tensioners. I am going to run it this way, may need to revisit that at a later time. I bought a converted oil cooler which had a leak at the fitting. I had Patrick MS re-do the fitting with a clean and pressure test. Along with that I had the flywheel balanced and put in a stage 2 clutch package with an aluminum faced pressure plate from Kennedy. I used ARP flywheel bolts and tossed the washer as the instructions stated to do. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 09:13 AM |
