Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 5 2018, 12:28 AM
With all this welding that I have to do, it is time for some door braces. I used 3/4 black pipe from HD and some right and left thread rod ends & inserts from McMaster. The seat belt bolts were a smidgenfuck too large to fit through the rod ends. I put the bolts in the drill press and used a file to make it the right size. I made the brakets that attach to the longs from some rectangular tubing.
Note to self - I will need to get new seat belt bolts! Attached thumbnail(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 07:20 AM |
