Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 5 2018, 12:42 AM
I have the transmission all bolted up to the engine. I also replaced the alternator with one that had an internal voltage regulator so won't have to use the stock relay board. Perry Kiehl fabricated a conversion wiring harness for me, it is some great craftsmanship. It would be a serious horror show to see what it would look like if I made one (IMG:style_emoticons/default/laugh.gif)
A couple years ago I found a 914-6 engine tin set on ebay for a couple hundred bucks. It was raw steel so I had this powder coated in a matte black. The side tins will need to go in after the engine is in the car, the polybronze rear bushing shaft sticks out farther than the stock pivot arm - found this out the hard way when taking the 4 cyl out and it hung up there. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 23rd April 2024 - 09:25 AM |
