Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
porschetub |
Jun 12 2018, 11:54 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done. My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Nice car ,that paint (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) ,welcome to the madness of a six conversion,looks like you are well on the way with some great parts already. Try to look into replacing the solid chain tentioners they are for cam setup or race engines that get freshened often,they place unwanted load on the chains and intermediate shaft and bearings. Buy some good used mechanical ones and rebuild them,pretty sure the rebuild kits are still for sale,fit chain saver collars and you will be golden. What plans have you for an engine mount,oil tank and shifter rod?. Keep up the good work ,I personally enjoy six conversions ,the finished job is the best part when folks find out after a first test drive how well they go (IMG:style_emoticons/default/beerchug.gif) . |
Lo-Fi Version | Time is now: 25th April 2024 - 06:49 AM |
