Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 14 2018, 10:50 PM
I started grinding the paint away where I needed to weld in the mounts, and I cut part of the tailshifter flange off to give me more room to weld.
Prepped with UPOL Weld through primer. I then fitted up the mounts and traced around the welding area and ground back down to bare metal. I don't have good luck welding directly through the primer. I then drilled some plug weld holes in the mounts. If I was to do it again, I would have only done the top two holes. Painted the backside with weld through primer, took off the primer on the plug weld holes and the edges of the mount. Attached image(s) |
Lo-Fi Version | Time is now: 18th April 2024 - 11:21 AM |
