Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 16 2018, 11:11 AM
I thought about leaving the mounts in when I had them halfway out. I was getting frustrated that I might not be able to get them out without a huge leftover mess!
I like the overlays and am thinking about something similar. Ollie's 914-6 blog has something like that as well. I will decide once I get the longs all fixed up. I took Ben's critique on my mounts and while I didn't really like to hear it, I needed to. And I am thankful to get the feedback. So I went out and did some practicing and fooling around with the controls. I am going to try to practice a little bit each day before I start doing any more weld in work. Also on plug & butt welds. It's easy to rush to get something done vs. trying the best you can and slow down a bit. Attached image(s) |
mb911 |
Jun 16 2018, 11:20 AM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I thought about leaving the mounts in when I had them halfway out. I was getting frustrated that I might not be able to get them out without a huge leftover mess! I like the overlays and am thinking about something similar. Ollie's 914-6 blog has something like that as well. I will decide once I get the longs all fixed up. I took Ben's critique on my mounts and while I didn't really like to hear it, I needed to. And I am thankful to get the feedback. So I went out and did some practicing and fooling around with the controls. I am going to try to practice a little bit each day before I start doing any more weld in work. Also on plug & butt welds. It's easy to rush to get something done vs. trying the best you can and slow down a bit. Looks very good.. Big improvement. Remember I have done it professionally for 25 years plus. It takes a while to be able to weld like this. |
Lo-Fi Version | Time is now: 25th April 2024 - 04:39 PM |
