Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 16 2018, 03:26 PM
More practice today. I won't keep boring you with all this, but I am happy about the improvement and wanted to share.
I found that doing the plug welds, I got the best penetration by starting the puddle in the middle and pull out to the side of the hole, then do the same in 3, 6, 9, 12 & follow up with filling the hole. Where I filled the hole in one shot, amazingly I had the least penetration. For the welds on the top, I redialed in my auto-darkening helmet so I could see better as i go. I did about 2" at a time and still need more practice were I start a weld next to the old weld (hope that makes sense). Also need to focus on using all the real estate on the side of the flat stock. This is new metal to new metal, so no blowing holes. I practiced on some old sheet metal I cut out of the car and that was much more tricky to not blow holes. Attached image(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 10:27 PM |
