Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
bbrock |
Jun 18 2018, 05:00 PM
I have the same cheapo HF bending brake and bending the radius on those inner longs is actually pretty easy. I welded a piece of 3/8" solid round stock to a piece of plate that I bent the patch around. Matches the radius very well. You can see it about half way down on this post: http://www.914world.com/bbs2/index.php?s=&...t&p=2516927
TravisNeff |
Jun 18 2018, 06:27 PM
I have the same cheapo HF bending brake and bending the radius on those inner longs is actually pretty easy. I welded a piece of 3/8" solid round stock to a piece of plate that I bent the patch around. Matches the radius very well. You can see it about half way down on this post: http://www.914world.com/bbs2/index.php?s=&...t&p=2516927 Giddyup! That will save me a whole day trying a bunch of different things. Thank you Brent. |
Lo-Fi Version | Time is now: 28th March 2024 - 05:23 AM |
