Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
bbrock |
Jun 18 2018, 05:00 PM
I have the same cheapo HF bending brake and bending the radius on those inner longs is actually pretty easy. I welded a piece of 3/8" solid round stock to a piece of plate that I bent the patch around. Matches the radius very well. You can see it about half way down on this post: http://www.914world.com/bbs2/index.php?s=&...t&p=2516927
TravisNeff |
Jun 18 2018, 06:27 PM
I have the same cheapo HF bending brake and bending the radius on those inner longs is actually pretty easy. I welded a piece of 3/8" solid round stock to a piece of plate that I bent the patch around. Matches the radius very well. You can see it about half way down on this post: http://www.914world.com/bbs2/index.php?s=&...t&p=2516927 Giddyup! That will save me a whole day trying a bunch of different things. Thank you Brent. |
bbrock |
Jun 18 2018, 07:31 PM
I have the same cheapo HF bending brake and bending the radius on those inner longs is actually pretty easy. I welded a piece of 3/8" solid round stock to a piece of plate that I bent the patch around. Matches the radius very well. You can see it about half way down on this post: http://www.914world.com/bbs2/index.php?s=&...t&p=2516927 Giddyup! That will save me a whole day trying a bunch of different things. Thank you Brent. Double check the radius of the rod stock. IIRC, the inner has the sharper radius which the 3/8" rod fit nicely. The outer was shallower and I think I used a 1/2" rod to fit the radius. Also, the first time I tried to bend a long piece of 18 ga with the HF brake, I snapped the crappy welds on the gizmo. No biggie to reweld solidly but might be worth doing preemptively. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 09:00 PM |
