Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 23 2018, 09:57 PM
I put in the backing panel against the inside long wall. I had to leave a gap so I could get the welding gun in there to weld to the side of the long. Then added in a filler piece with a flange so I could plug weld and run a stitch at the seam. Its a little ugly, but it will be covered up.
Went on to make the bottom of the long to cover the same area. Made 2 recess to replicate the original long. I made them about a 1/4 to wide, and thought hard about making another panel. Then I said screw it, it will all be covered by seam sealer anyways. It's in, I'll share pics tomorrow for that. Attached image(s) |
Lo-Fi Version | Time is now: 23rd April 2024 - 03:36 PM |
