Travis' 72 914-6 Conversion |
TravisNeff |
Jun 4 2018, 11:32 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox. The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap. Here's what I am starting with. Attached thumbnail(s) |
TravisNeff |
Jun 23 2018, 09:57 PM
I put in the backing panel against the inside long wall. I had to leave a gap so I could get the welding gun in there to weld to the side of the long. Then added in a filler piece with a flange so I could plug weld and run a stitch at the seam. Its a little ugly, but it will be covered up.
Went on to make the bottom of the long to cover the same area. Made 2 recess to replicate the original long. I made them about a 1/4 to wide, and thought hard about making another panel. Then I said screw it, it will all be covered by seam sealer anyways. It's in, I'll share pics tomorrow for that. Attached image(s) |
mb911 |
Jun 24 2018, 05:00 AM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I put in the backing panel against the inside long wall. I had to leave a gap so I could get the welding gun in there to weld to the side of the long. Then added in a filler piece with a flange so I could plug weld and run a stitch at the seam. Its a little ugly, but it will be covered up. Went on to make the bottom of the long to cover the same area. Made 2 recess to replicate the original long. I made them about a 1/4 to wide, and thought hard about making another panel. Then I said screw it, it will all be covered by seam sealer anyways. It's in, I'll share pics tomorrow for that. Sorry I didn't get back to you on that.. Looks like you figured it out.. |
TravisNeff |
Jun 24 2018, 10:08 AM
I put in the backing panel against the inside long wall. I had to leave a gap so I could get the welding gun in there to weld to the side of the long. Then added in a filler piece with a flange so I could plug weld and run a stitch at the seam. Its a little ugly, but it will be covered up. Went on to make the bottom of the long to cover the same area. Made 2 recess to replicate the original long. I made them about a 1/4 to wide, and thought hard about making another panel. Then I said screw it, it will all be covered by seam sealer anyways. It's in, I'll share pics tomorrow for that. Sorry I didn't get back to you on that.. Looks like you figured it out.. No problemo. It helped that your picture had the length written on them! Only took about 10 minutes from start to end. |
Lo-Fi Version | Time is now: 25th April 2024 - 12:09 AM |
