Wiper Switch |
Wiper Switch |
partwerks |
Jun 5 2018, 06:42 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Was it the 924 with a wiper switch that would work on a 914 that was electrical?
Valy |
Jun 5 2018, 07:58 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Jun 5 2018, 08:19 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Just to be clear, neither of those will work on an early 914 which had the wiper switch on the dash ...
(IMG:style_emoticons/default/shades.gif) |
partwerks |
Jun 5 2018, 09:01 PM
Was it the 924 with a wiper switch that would work on a 914 that was electrical? That will work. But the best one is from the latest super beattle. They have support for electric pump. I have a 1975. Do you have a part number for that, or a link to one, so I'm sure of getting the correct thing. This work: https://vwparts.aircooled.net/Windshield-Wi...11-953-519g.htm |
db9146 |
Jun 6 2018, 07:11 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Just to be clear, neither of those will work on an early 914 which had the wiper switch on the dash ... (IMG:style_emoticons/default/shades.gif) Sir Andy, have you got a pic of an early dash-mounted wiper switch? Not sure I've ever seen one of those. |
914Sixer |
Jun 6 2018, 07:40 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
1975-76 wiper switch is unique. It has a lower cut plastic ring than the earlier versions. It was sourced from the VW Rabbit. Real hard item to find.
Valy |
Jun 6 2018, 07:57 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G
The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. |
partwerks |
Jun 6 2018, 08:27 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? |
914Sixer |
Jun 6 2018, 08:29 PM
Yes, IF it has 6 pins.
partwerks |
Jun 6 2018, 08:57 PM
Mine only has 5.
Valy |
Jun 6 2018, 09:25 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. |
worn |
Jun 6 2018, 10:52 PM
can't remember Group: Members Posts: 3,147 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. I just got to use my switch coupled to the “99” relay from vw. You push the lever down and then back up, and then when it is time for another sweep push down agai. After that it remembers the interval. Pull back and you get washer fluid plus a couple sweeps. You need to add an additional relay, but it sure is slick. |
partwerks |
Jun 13 2018, 07:13 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. Getting a bit ahead of myself at this point, but the mechanics Wife left me a note, saying the wiper switch showed up today, and is wrong. So I'll have to call him tomorrow and see what the problem is this time? Wasn't this the switch that was suppose to work on a 75? |
porschetub |
Jun 14 2018, 12:58 AM
You can add in another wire to the contact and make the washer work through a relay,pretty sure that's what I did.....memories hopeless (IMG:style_emoticons/default/sad.gif)
rgalla9146 |
Jun 14 2018, 05:34 AM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. I just got to use my switch coupled to the “99” relay from vw. You push the lever down and then back up, and then when it is time for another sweep push down agai. After that it remembers the interval. Pull back and you get washer fluid plus a couple sweeps. You need to add an additional relay, but it sure is slick. The above relay is often used in Vanagons |
Lo-Fi Version | Time is now: 26th April 2024 - 12:41 AM |
