> Wiper Switch
partwerks
post Jun 5 2018, 06:42 PM
Was it the 924 with a wiper switch that would work on a 914 that was electrical?
Valy
post Jun 5 2018, 07:58 PM
QUOTE(partwerks @ Jun 5 2018, 05:42 PM) *
That will work. But the best one is from the latest super beattle. They have support for electric pump.
post Jun 5 2018, 08:19 PM
Resident German
Just to be clear, neither of those will work on an early 914 which had the wiper switch on the dash ...
partwerks
post Jun 5 2018, 09:01 PM
QUOTE(Valy @ Jun 5 2018, 05:58 PM) *
I have a 1975. Do you have a part number for that, or a link to one, so I'm sure of getting the correct thing.
This work: https://vwparts.aircooled.net/Windshield-Wi...11-953-519g.htm
db9146
post Jun 6 2018, 07:11 AM
QUOTE(SirAndy @ Jun 5 2018, 10:19 PM) *
Sir Andy, have you got a pic of an early dash-mounted wiper switch? Not sure I've ever seen one of those.
914Sixer
post Jun 6 2018, 07:40 AM
1975-76 wiper switch is unique. It has a lower cut plastic ring than the earlier versions. It was sourced from the VW Rabbit. Real hard item to find.
Valy
post Jun 6 2018, 07:57 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G
The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well.
You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay.
The link I posted supports everything.
partwerks
post Jun 6 2018, 08:27 PM
QUOTE(Valy @ Jun 6 2018, 05:57 PM) *
Would the 914 switch with number: 91461330618 work with an electric pump as well?
914Sixer
post Jun 6 2018, 08:29 PM
Yes, IF it has 6 pins.
partwerks
post Jun 6 2018, 08:57 PM
Mine only has 5.
Valy
post Jun 6 2018, 09:25 PM
QUOTE(partwerks @ Jun 6 2018, 07:27 PM) *
No. None of the original 914 wiper switches were designed to work with an electric pump.
worn
post Jun 6 2018, 10:52 PM
can't remember
QUOTE(Valy @ Jun 6 2018, 07:25 PM) *
I just got to use my switch coupled to the “99” relay from vw. You push the lever down and then back up, and then when it is time for another sweep push down agai. After that it remembers the interval. Pull back and you get washer fluid plus a couple sweeps. You need to add an additional relay, but it sure is slick.
partwerks
post Jun 13 2018, 07:13 PM
Getting a bit ahead of myself at this point, but the mechanics Wife left me a note, saying the wiper switch showed up today, and is wrong. So I'll have to call him tomorrow and see what the problem is this time?
Wasn't this the switch that was suppose to work on a 75?
porschetub
post Jun 14 2018, 12:58 AM
You can add in another wire to the contact and make the washer work through a relay,pretty sure that's what I did.....memories hopeless (IMG:style_emoticons/default/sad.gif)
rgalla9146
post Jun 14 2018, 05:34 AM
QUOTE(worn @ Jun 7 2018, 12:52 AM) *
The above relay is often used in Vanagons
- Lo-Fi Version Time is now: 16th April 2024 - 09:54 AM
