Wiper Switch |
Wiper Switch |
partwerks |
Jun 5 2018, 06:42 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Was it the 924 with a wiper switch that would work on a 914 that was electrical?
Valy |
Jun 6 2018, 07:57 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G
The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. |
partwerks |
Jun 6 2018, 08:27 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? |
Valy |
Jun 6 2018, 09:25 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. |
partwerks |
Jun 13 2018, 07:13 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. Getting a bit ahead of myself at this point, but the mechanics Wife left me a note, saying the wiper switch showed up today, and is wrong. So I'll have to call him tomorrow and see what the problem is this time? Wasn't this the switch that was suppose to work on a 75? |
Lo-Fi Version | Time is now: 17th May 2024 - 12:00 PM |
