Wiper Switch |
Wiper Switch |
partwerks |
Jun 5 2018, 06:42 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Was it the 924 with a wiper switch that would work on a 914 that was electrical?
Valy |
Jun 6 2018, 07:57 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G
The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. |
partwerks |
Jun 6 2018, 08:27 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? |
Valy |
Jun 6 2018, 09:25 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. |
Lo-Fi Version | Time is now: 1st May 2024 - 10:06 PM |
