Wiper Switch |
Wiper Switch |
partwerks |
Jun 5 2018, 06:42 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Was it the 924 with a wiper switch that would work on a 914 that was electrical?
Valy |
Jun 6 2018, 07:57 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G
The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. |
partwerks |
Jun 6 2018, 08:27 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? |
Valy |
Jun 6 2018, 09:25 PM
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. |
worn |
Jun 6 2018, 10:52 PM
can't remember Group: Members Posts: 3,149 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. I just got to use my switch coupled to the “99” relay from vw. You push the lever down and then back up, and then when it is time for another sweep push down agai. After that it remembers the interval. Pull back and you get washer fluid plus a couple sweeps. You need to add an additional relay, but it sure is slick. |
rgalla9146 |
Jun 14 2018, 05:34 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G The extra wire is for an electric pump, if you want it. If not, the air pressure valve works as well. You will see 4 and 6 wires variants. The 4 Wire doesn't support the intermittent relay. The link I posted supports everything. Would the 914 switch with number: 91461330618 work with an electric pump as well? No. None of the original 914 wiper switches were designed to work with an electric pump. I just got to use my switch coupled to the “99” relay from vw. You push the lever down and then back up, and then when it is time for another sweep push down agai. After that it remembers the interval. Pull back and you get washer fluid plus a couple sweeps. You need to add an additional relay, but it sure is slick. The above relay is often used in Vanagons |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:11 AM |
