914rubber, Stand up guys |
mmichalik |
Jun 8 2018, 08:03 AM
MikeM Group: Members Posts: 689 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I know it's been said before but, I want to say it again. Mark and Scott, and the rest of the crew at 914rubber.com, are stand up guys.
There customer service and customer appreciation is very high. Thanks for everything you guys have helped me with so far. Mike |
Mikey914 |
Jun 12 2018, 04:13 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Already made them in rubber. The paper tears when you try to install. I can do in the "correct" material if you wish, but they are not easy to install.
https://shop.914rubber.com/914-Early-gas-ca...m?categoryId=-1 Attached thumbnail(s) |
bdstone914 |
Jun 12 2018, 06:41 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Already made them in rubber. The paper tears when you try to install. I can do in the "correct" material if you wish, but they are not easy to install. https://shop.914rubber.com/914-Early-gas-ca...m?categoryId=-1 I think the OP means the rubber cup shaped part down below the metal parts. To get them out you need to uncurl one of the three crimps that hold the cap together. If you are that far you might as well get anew cap. They are the same as a VW Beettle cap. They may not be good quality. will try the one I have to see how if fits. |
Lo-Fi Version | Time is now: 24th April 2024 - 10:00 PM |
