> Sail panel bottom trim hole size?
914xr75
post Jun 9 2018, 10:30 AM
I'm trying to find out the size of the four holes that fit the bottom bright trim on the sail panel. If anyone can help me out with their calipers I'd appreciate it. My car does not have the appearance group but I really like the look of the vinyl. ThanksAttached Image
post Jun 9 2018, 11:23 AM
QUOTE(914xr75 @ Jun 9 2018, 09:30 AM) *
Not much to offer up to your question but...............if your using the new clips for Sierra Madre you will need to increase the OEM hole size 2 or 3 sizes. Otherwise you will ruin that small trim piece. Ask me how I know. (IMG:style_emoticons/default/mad.gif)
914xr75
post Jun 9 2018, 10:45 PM
Thanks for the info. I'm actually using original Porsche clips. I was trying to avoid buying multiple sizes of drill bits.
cn2800
post Jun 10 2018, 12:52 PM
I measured all of mine with a digital micrometer, and got a range from 5.1 to 5.3 millimeters.
914xr75
post Jun 15 2018, 11:21 PM
I just came back to my post to add the answer to this question and found out that someone came to my rescue. Thank you so much cn2800. Awesome. 5 mm is what I figured out. I'm sure if I put a caliper to my new holes they'd be the same range you have. Thanks again. Hopefully I can help you out one day with an answer.
- Lo-Fi Version Time is now: 16th April 2024 - 12:16 PM
