New GB LED replacment Bulbs $99 a set, Option for H4 housings for those that need them |
djway |
Jul 1 2018, 10:52 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Hand up
jcschuf1 |
Jul 2 2018, 09:30 AM
Newbie Group: Members Posts: 13 Joined: 23-September 12 From: Maple Grove, MN Member No.: 14,969 Region Association: Upper MidWest |
Please put me down for one set as well! Thanks!
iankarr |
Jul 2 2018, 11:49 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I'm in for a set. And an install video!
tyfighter123 |
Jul 4 2018, 09:02 PM
Newbie Group: Members Posts: 41 Joined: 22-September 16 From: Grand Junction Member No.: 20,422 Region Association: Rocky Mountains |
Ill take 2 sets.....
Tbrown4x4 |
Jul 5 2018, 08:27 PM
Senior Member Group: Members Posts: 699 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
One set with lenses and a throttle cable. (IMG:style_emoticons/default/poke.gif)
jim_hoyland |
Feb 3 2019, 09:04 PM
Get that VIN ? Group: Members Posts: 9,255 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’v been using the LED conversion set and find them quite good. However, I would like to know the specifications for the bulbs; i’m Looking at a pair of STK H4 9003 bulbs. Are these going to be compatible ?
These bulbs emit yellow ad low beams and bright white in high beam mode. Attached thumbnail(s) |
bandjoey |
Feb 3 2019, 09:24 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Possibly illegal in yellow. Check with your friendly lawman first.
ConeDodger |
Feb 4 2019, 12:52 AM
Apex killer! Group: Members Posts: 23,552 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Something I want to point out, since this is my car in the picture, this picture doesn’t even compare stock to the new LED bulbs. On the left is a halogen H4 bulb.
andreic |
Feb 4 2019, 01:36 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Is this group buy still available? I am interested in a pair.
Mikey914 |
Feb 5 2019, 11:57 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes Matt is about to open it up with the new headlight surrounds and the complete rebuild for all the bushings in both early and late (including the early brush and rubber flap set up).
@matty900 That will let him know you are interested and you should see the rest in the next day as it comes together. -Mark |
porschetub |
Feb 6 2019, 12:58 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I’v been using the LED conversion set and find them quite good. However, I would like to know the specifications for the bulbs; i’m Looking at a pair of STK H4 9003 bulbs. Are these going to be compatible ? These bulbs emit yellow ad low beams and bright white in high beam mode. Using a similar white 55w set with H4 housings and they work very well,however further research indicated they may not be legal in my country but I haven't really had the time to find out why. |
horizontally-opposed |
Feb 6 2019, 02:54 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Interested. GB price?
So they're plug and play if you've got H4s? I do... |
914werke |
Feb 6 2019, 03:45 PM
"I got blisters on me fingers" Group: Members Posts: 9,995 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Yes Matt is about to open it up with the new headlight surrounds and the complete rebuild for all the bushings in both early and late (including the early brush and rubber flap set up). @matty900 That will let him know you are interested and you should see the rest in the next day as it comes together. -Mark Curious if there has been a solution for the rubber boot sealing the element to the housing? |
1adam12 |
Feb 6 2019, 04:24 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
I'm in for a set !
ConeDodger |
Feb 6 2019, 05:33 PM
Feb 6 2019, 05:44 PM
Pete, Yes. 10 minutes a side to install. Thanks Rob! Curious if there has been a solution for the rubber boot sealing the element to the housing? Okay, see the price (sorry for asking!), and just curious about the question above. Hmm, may need to do this. Don't often drive my car at night, but what a shockingly bad system it is after being spoiled by modern systems. And…getting older.... |
ConeDodger |
Feb 6 2019, 05:55 PM
Pete, Yes. 10 minutes a side to install. Thanks Rob! Curious if there has been a solution for the rubber boot sealing the element to the housing? Okay, see the price (sorry for asking!), and just curious about the question above. Hmm, may need to do this. Don't often drive my car at night, but what a shockingly bad system it is after being spoiled by modern systems. And…getting older.... Pete, the rubber cover doesn’t really fit, but I don’t worry about it as I never drive in the rain. I can practically hear the damn thing rusting as it is! (IMG:style_emoticons/default/biggrin.gif) |
Matty900 |
Feb 7 2019, 12:55 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
Yes Matt is about to open it up with the new headlight surrounds and the complete rebuild for all the bushings in both early and late (including the early brush and rubber flap set up). @matty900 That will let him know you are interested and you should see the rest in the next day as it comes together. -Mark Curious if there has been a solution for the rubber boot sealing the element to the housing? I sent you the prototype, how did it work for you? |
914werke |
Feb 7 2019, 04:03 AM
When? I hadnt received anything?
Matty900 |
Feb 8 2019, 02:17 AM
When? I hadnt received anything? They went to you in December. I have not driven my car in the rain to test them so I was hoping for some feedback from you. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th April 2024 - 01:05 AM |
