New GB LED replacment Bulbs $99 a set, Option for H4 housings for those that need them |
dwillouby |
Feb 11 2019, 10:22 AM
Member Group: Members Posts: 391 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Group buy still available?
Need bulbs & lenses. How to order? David |
914werke |
Feb 11 2019, 01:45 PM
"I got blisters on me fingers" Group: Members Posts: 9,894 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Bummer. The foam seal makes sense. Must have gotten lost in the post.
falcor75 |
Apr 12 2019, 10:42 PM
Senior Member Group: Members Posts: 1,578 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Just a heads up for those of you that have to pass strict mot checks with your 914's is that these LED bulbs might fail the check due to poor light pattern. No amount of adjusting would get the beams low enough to avoid blinding oncoming traffic so I got a fail on both. Switched back to regular H4 halogens and the light pattern became crisp as a razor again.
Mikey914 |
Apr 13 2019, 09:54 AM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Other than a high / low beam light (as the lows are hooded), the diffusion of the light is a function of the lens. We had included the EMPI lenses as they were inexpensive and had been commercially proven. The Hella lenses are $70 each. May be a viable option if you are having issues.
FlacaProductions |
Apr 13 2019, 10:18 AM
Senior Member Group: Members Posts: 1,521 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I have H4's but the reflectors seem to be deteriorated/flaky/moldy (the car is new to me...) and need to go. I was considering going full LED with the Truck-Lite's but can I use your LED lamps with your OEM91463110600 headlight globe or am I best to go with Hella H4 lenses - I'm betting the latter....
Mikey914 |
Apr 14 2019, 01:12 PM
I'm using the EMPI ones (that we stock), and have found to be a 100% improvement over factory. The Hella lenses (my personal opinion), didn't justify spending 3-4x the amount on.
Try the Empis and if you don't like them send them back for a refund. You're only gambling the shipping cost, but I'd bet you'll like them. |
bandjoey |
Apr 14 2019, 03:50 PM
bandjoey Group: Members Posts: 4,920 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
LED is the way to go. I drove dusk to dawn cross country and visibility was perfect. Will not go back. AS TO cutoff. I use the E Hella lens. Imagine a letter E pattern. I can set a severe upper cut off and still super long distance lighting.
I’ll post a picture tonight |
FlacaProductions |
Apr 14 2019, 10:29 PM
Thanks @Mikey914 - I'll put that on the list i'm building - thank you!
ovilla |
May 6 2019, 12:39 AM
Member Group: Members Posts: 84 Joined: 25-February 05 From: Plainfield, IL Member No.: 3,660 |
Do you have to use 12V relays with these bulbs/kit or is the wattage safe enough to go through the factory headlight switch?
Mikey914 |
May 6 2019, 10:46 AM
Plug and play, the only issue can be the relay NOT getting enough wattage to trigger it. These use a fraction of the the incandescent bulbs.
ovilla |
May 8 2019, 11:48 PM
Put me down for one set please. I already have Hella lenses. When/where do I pay you?
Mikey914 |
May 9 2019, 05:12 PM
Lo-Fi Version | Time is now: 28th March 2024 - 05:18 PM |
