Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I've been making these for quite some time and we are finally through with our 1st 100 units! In the process of doing up more now, so you can save some cash. We are also making some modification mounts form 1/2" steel that will allow you to use an inexpensive HF tow bar. They will be available as an option for those that choose for $25.
This bar is set up to use the EMPI beetle tow bar and I've recently been told you can get them on Amazon with the lights for $159. Also, mine will allow for mounting to not have to remove the valance with the LE option. Nice to know I can be hooked up in about 10 min ready to go and disconnect in about 5. It's nice having the piece of mind that if my car decides it not working, I can hook right up and tow it home. Also the long drives the wife prefers the truck, and I can drive or tow it. Attached thumbnail(s) ![]() ![]() |
Lo-Fi Version | Time is now: 9th July 2025 - 08:31 AM |
