possible dead battery?, 11.78 V |
914 RZ-1 |
Jun 10 2018, 09:56 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
1. My car has been sitting for awhile, but it has started up when I needed it to.
I recently took out and put back the transmission. I got everything hooked up and the car would not start. I took a reading across the battery terminals and got 11.87 volts. Is this an indication of a dead battery? 2. I should mention that I unhooked the positive and negative terminals while the trans was out. I also have a battery disconnect on the negative terminal (turn a screw to connect/disconnect). I got sparks when I hooked up the positive and touched the wrench to the car accidentally. 3. I have an Optima Red Top battery that is only about 1-2 years old. 4. I checked all the wire connections related to the trans and didn't see anything. That shouldn't matter anyway, I think. 5. I'm thinking of jump-starting the car and seeing if that works. 6. I'm also thinking of getting a battery charger and hooking that up. Thoughts? |
Chris914n6 |
Jun 11 2018, 12:04 PM
Jackstands are my life. Group: Members Posts: 3,307 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
A dead cell would make it 10.5v. That just sounds low -- in need of charging.
Optimas hate cheap chargers. Spend the $50+ on a smart charger with trickle. A battery at rest will hover around 12.5v |
Bartlett 914 |
Jun 11 2018, 12:48 PM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
A dead cell would make it 10.5v. That just sounds low -- in need of charging. Optimas hate cheap chargers. Spend the $50+ on a smart charger with trickle. A battery at rest will hover around 12.5v (IMG:style_emoticons/default/agree.gif) I gave up on Optima batteries. They are sensitive to proper charging and they rellay don't like being drained too low. These issues gave me a short life with them. |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:43 AM |
