possible dead battery?, 11.78 V |
914 RZ-1 |
Jun 10 2018, 09:56 PM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
1. My car has been sitting for awhile, but it has started up when I needed it to.
I recently took out and put back the transmission. I got everything hooked up and the car would not start. I took a reading across the battery terminals and got 11.87 volts. Is this an indication of a dead battery? 2. I should mention that I unhooked the positive and negative terminals while the trans was out. I also have a battery disconnect on the negative terminal (turn a screw to connect/disconnect). I got sparks when I hooked up the positive and touched the wrench to the car accidentally. 3. I have an Optima Red Top battery that is only about 1-2 years old. 4. I checked all the wire connections related to the trans and didn't see anything. That shouldn't matter anyway, I think. 5. I'm thinking of jump-starting the car and seeing if that works. 6. I'm also thinking of getting a battery charger and hooking that up. Thoughts? |
914 RZ-1 |
Jun 11 2018, 11:36 AM
I reconnected everything, including the ground strap.
I'm wondering what the correct reading for a good battery should be. I seem to remember reading that anything lower than 12 volts is considered in need of recharging. |
SirAndy |
Jun 11 2018, 11:53 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm wondering what the correct reading for a good battery should be. I seem to remember reading that anything lower than 12 volts is considered in need of recharging. Without anything drawing from it, the reading should be in the 14v range on a good battery. However, that can be misleading since it easily can drop and not work correctly when you put load on it, even if it reads high otherwise. Get a cheap charger and hook it up and see if the battery comes back ... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 09:53 PM |
