possible dead battery?, 11.78 V |
914 RZ-1 |
Jun 10 2018, 09:56 PM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
1. My car has been sitting for awhile, but it has started up when I needed it to.
I recently took out and put back the transmission. I got everything hooked up and the car would not start. I took a reading across the battery terminals and got 11.87 volts. Is this an indication of a dead battery? 2. I should mention that I unhooked the positive and negative terminals while the trans was out. I also have a battery disconnect on the negative terminal (turn a screw to connect/disconnect). I got sparks when I hooked up the positive and touched the wrench to the car accidentally. 3. I have an Optima Red Top battery that is only about 1-2 years old. 4. I checked all the wire connections related to the trans and didn't see anything. That shouldn't matter anyway, I think. 5. I'm thinking of jump-starting the car and seeing if that works. 6. I'm also thinking of getting a battery charger and hooking that up. Thoughts? |
rhodyguy |
Jun 11 2018, 01:24 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,054 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Plenty of info out there about charging gel batteries. Beyond a certain point, you need to use the parallel charging method.
Lo-Fi Version | Time is now: 19th April 2024 - 06:38 AM |
