possible dead battery?, 11.78 V |
914 RZ-1 |
Jun 10 2018, 09:56 PM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
1. My car has been sitting for awhile, but it has started up when I needed it to.
I recently took out and put back the transmission. I got everything hooked up and the car would not start. I took a reading across the battery terminals and got 11.87 volts. Is this an indication of a dead battery? 2. I should mention that I unhooked the positive and negative terminals while the trans was out. I also have a battery disconnect on the negative terminal (turn a screw to connect/disconnect). I got sparks when I hooked up the positive and touched the wrench to the car accidentally. 3. I have an Optima Red Top battery that is only about 1-2 years old. 4. I checked all the wire connections related to the trans and didn't see anything. That shouldn't matter anyway, I think. 5. I'm thinking of jump-starting the car and seeing if that works. 6. I'm also thinking of getting a battery charger and hooking that up. Thoughts? |
914 RZ-1 |
Jun 13 2018, 10:13 AM
I solved the problem!
I tried using a jump box. Nothing. Tried jumper cables. Nothing. It occurred to me that it must be a connection somewhere, since when I connected the battery cables, the CD player cycled and I could cycle the fuel pump when I turned the ignition. It was just the starter that wasn't engaging at all. 1. Battery cables were not connected tightly. 2. Loose connection on hot start relay. Car fired right up when I corrected these issues. I did buy a battery tender to keep the battery charged while the car is sitting. Thanks to all for your input! |
Lo-Fi Version | Time is now: 24th April 2024 - 04:10 AM |
