GB early fog light rebuild "kit" $75 (option to add grills)GB ends July1, Lenses, seals, retainer springs, protective cover enought for 1 car |
Mikey914 |
Jun 11 2018, 12:38 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are setting up a GB for fog light rebuilds.
It includes - 2 - TN1-2 or TN4 lenses Clear (I have a limited quantity of amber at $3 each more) 2 - fog light gaskets 10 - Spring retainer clips 2 rock chip protectors for the lenses, as these will get pitted without them. $75 a set clear $81 amber So who needs to rebuild thiers? Also as a special only for those that add onto thier kit you can get a set of fog light grills for $88 in chrome, $75 in black. Attached thumbnail(s) |
Rob-O |
Jun 12 2018, 05:06 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Details? Is the Gb on the site or working on it?
Mikey914 |
Jun 13 2018, 09:52 AM
Details? Is the Gb on the site or working on it? Bump the thread I send you the codes. You should have in you PMs now. And even if you have a great set of these. You should look at using the fog light lens protectors on the site. The will give you a protective layer. Will decrease the chance of breaking if hit, and hold it together if it does. But mostly because of the sand blast effect. You can't polish that out (at least without commercial equipment). |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:10 AM |
