Replacing trunk firewall perlon, How did you do it and other questions.... |
jim_hoyland |
Jun 11 2018, 04:55 PM
Get that VIN ? Group: Members Posts: 9,287 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I acquired a new piece of pre-cut perlon from 914Rubber and have done some limited test fitting. Since I only get one shot at gluing the perlon, i’m Looking for advice from someone that’s done this.
Type of glue, tools, solo or Help . Attached thumbnail(s) |
jim_hoyland |
Jun 11 2018, 06:39 PM
Thanks. Good suggestion to mask; did you spray the perlon and metal, or just the metal. And where did you start when attaching the perlon ?
It was suggested I use Loctite300; I have some 3M 77 in the cabinate? Gotta decide what to use |
Lucky9146 |
Jun 11 2018, 09:09 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,613 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Thanks. Good suggestion to mask; did you spray the perlon and metal, or just the metal. And where did you start when attaching the perlon ? It was suggested I use Loctite300; I have some 3M 77 in the cabinate? Gotta decide what to use I sprayed both. Use 3M 77 will be fine. Wish I could remember exactly how I started but I think I started at the top making sure it was perfectly centered and worked my way down. You said you did pre fit so should be fine. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
Lo-Fi Version | Time is now: 14th May 2024 - 09:57 AM |
