Replacing trunk firewall perlon, How did you do it and other questions.... |
jim_hoyland |
Jun 11 2018, 04:55 PM
Get that VIN ? Group: Members Posts: 9,287 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I acquired a new piece of pre-cut perlon from 914Rubber and have done some limited test fitting. Since I only get one shot at gluing the perlon, i’m Looking for advice from someone that’s done this.
Type of glue, tools, solo or Help . Attached thumbnail(s) |
theer |
Jun 12 2018, 12:30 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
This is on my to-do list as well...
Probably not a huge deal, but ...at the top -does the carpet go all the way up the firewall including on the little flange where the truck seal sits? Said the other way around: does the trunk seal go over the flange and a bit of the carpet? |
Lucky9146 |
Jun 12 2018, 12:52 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,612 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
This is on my to-do list as well... Probably not a huge deal, but ...at the top -does the carpet go all the way up the firewall including on the little flange where the truck seal sits? Said the other way around: does the trunk seal go over the flange and a bit of the carpet? Correct! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
jim_hoyland |
Jun 12 2018, 04:56 PM
This is on my to-do list as well... Probably not a huge deal, but ...at the top -does the carpet go all the way up the firewall including on the little flange where the truck seal sits? Said the other way around: does the trunk seal go over the flange and a bit of the carpet? Correct! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) I had this question too; I just got a look at an original ‘73 and it appeared the felt just meets the rubber seal. Anyone else...... |
Lo-Fi Version | Time is now: 13th May 2024 - 03:04 PM |
