Headlights on but don't pop up |
rwiii |
Jun 12 2018, 09:02 PM
Newbie Group: Members Posts: 3 Joined: 1-October 13 From: Texas Member No.: 16,461 Region Association: None |
Went out to dinner and the headlights worked fine. Came out and they come on--you can see them on through the seem--but won't pop up. Both headlights. No noise, hesitation or anything. Just frozen in place.
Is there a fuse I can look for? If so where is it and the proper number (volt, H, Amp or whatever that number is). Is there something else I can check before taking it in? Thanks |
jcd914 |
Jun 13 2018, 12:06 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
It is the lower gasket for the L-Jet oil cap. This thread has a picture. No idea if Terry still has these available or not. It would be great if 914Rubber could make both the upper and lower gaskets. Pictures of the oil cap seal from the thread linked above: Jim Fuse 12 supplies power for the headlight motors. There is a gray wire from the headlight switch terminal K or 56K (depending on year) that provides the power to energize the headlight motor relays. Jim |
Lo-Fi Version | Time is now: 4th May 2024 - 11:01 AM |
