Headlights on but don't pop up |
rwiii |
Jun 12 2018, 09:02 PM
Newbie Group: Members Posts: 3 Joined: 1-October 13 From: Texas Member No.: 16,461 Region Association: None |
Went out to dinner and the headlights worked fine. Came out and they come on--you can see them on through the seem--but won't pop up. Both headlights. No noise, hesitation or anything. Just frozen in place.
Is there a fuse I can look for? If so where is it and the proper number (volt, H, Amp or whatever that number is). Is there something else I can check before taking it in? Thanks |
HalfMoon |
Jun 13 2018, 08:47 AM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Went out to dinner and the headlights worked fine. Came out and they come on--you can see them on through the seem--but won't pop up. Both headlights. No noise, hesitation or anything. Just frozen in place. Is there a fuse I can look for? If so where is it and the proper number (volt, H, Amp or whatever that number is). Is there something else I can check before taking it in? Thanks And I know this will sound odd, (but it actually happened to me), the contact points at the fuse holder can become so dirty they will not permit continuity. Clean them off with some Emory cloth. |
rwiii |
Jun 13 2018, 09:35 PM
Went out to dinner and the headlights worked fine. Came out and they come on--you can see them on through the seem--but won't pop up. Both headlights. No noise, hesitation or anything. Just frozen in place. Is there a fuse I can look for? If so where is it and the proper number (volt, H, Amp or whatever that number is). Is there something else I can check before taking it in? Thanks And I know this will sound odd, (but it actually happened to me), the contact points at the fuse holder can become so dirty they will not permit continuity. Clean them off with some Emory cloth. Yea, there is oxidation on the contacts. I did swap a working fuse and that wasn't the problem. I spun the black knob on the back of the motors and both go up and down fine. Again, lights work but neither go up or down. I'll clean the contacts but any other ideas are welcome! Thanks. |
Lo-Fi Version | Time is now: 20th April 2024 - 08:21 AM |
