Door latch, won't latch |
Abeck914 |
Jun 13 2018, 05:57 AM
Newbie Group: Members Posts: 25 Joined: 4-December 17 From: Rhode Island Member No.: 21,677 Region Association: None |
Hi all,
Anyone have an issue where their door won't latch? I see a lot of info on latches getting stuck/locked out. I can see the latch release when I use either outer or inner door handle. I set the latch in the correct position and when I close the door it won't close. When I close the door I can longer see what the latch is doing but I have to assume it is spring related? Can someone confirm the sierra madre door stay rebuild kit [and some cleaning] will get me back to operable door, or steer me in the correct direction. Thank you in advance, Aaron |
Abeck914 |
Jun 13 2018, 08:58 AM
OK,
when i use the handle to open the latch it swings open to the position (45 degree angle) that lines up with the striker. When it contacts the striker it doesn't "spring back" to complete the latching intent. So, I'll start with the cleaning, and then contact bdstone if frustration sets in/failure. Thanks for replying everyone [and not letting me order stuff that wont help!], Aaron |
Abeck914 |
Jun 13 2018, 11:20 AM
OK, when i use the handle to open the latch it swings open to the position (45 degree angle) that lines up with the striker. When it contacts the striker it doesn't "spring back" to complete the latching intent. So, I'll start with the cleaning, and then contact bdstone if frustration sets in/failure. Thanks for replying everyone [and not letting me order stuff that wont help!], Aaron Spring broke. and pep boys had one!! amazing |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:17 AM |
