Door latch, won't latch |
Abeck914 |
Jun 13 2018, 05:57 AM
Newbie Group: Members Posts: 25 Joined: 4-December 17 From: Rhode Island Member No.: 21,677 Region Association: None |
Hi all,
Anyone have an issue where their door won't latch? I see a lot of info on latches getting stuck/locked out. I can see the latch release when I use either outer or inner door handle. I set the latch in the correct position and when I close the door it won't close. When I close the door I can longer see what the latch is doing but I have to assume it is spring related? Can someone confirm the sierra madre door stay rebuild kit [and some cleaning] will get me back to operable door, or steer me in the correct direction. Thank you in advance, Aaron |
bdstone914 |
Jun 13 2018, 07:12 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Probably just need a good cleaning. There is a spring that can come off and cause the latch to not work. If you do ned a replacement I have replated cleaned ones ready to go.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 12:51 PM |
