WTB: high horse power VW 4-cylinder engine, What do you have? Must be primo. Plug and play. |
burton73 |
Jun 13 2018, 02:04 PM
burton73 Group: Members Posts: 3,493 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
WTB: high horse power VW 4-cylinder engine.
What do you have? Must be primo. Just not sure what I want to do on my 1970 1.7 car. Looking for options. Said no to stock 2.0 any ideas? Please run ideas by me! Bob B (IMG:style_emoticons/default/driving.gif) |
thelogo |
Jun 13 2018, 11:47 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Im switching to a /6
So the big 4 is available, 2366 with webbers an about 5k miles on it Total package for 8k $ But must do local pickup in sgv |
Jun 14 2018, 05:13 AM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mblizzard |
Jun 14 2018, 07:48 AM
I did a lot of research on this and you can find the conclusions here.
Most of these are long blocks but it certainly gives you an idea of possible starting points to move forward in cost to a plug an play. With that said, first pick your fuel delivery preference. Fuel injection or carbs. Both will work and have their pros and cons. But if you want performance a modern FI engine management system gives you a lot of control that you don't get with carbs. Stick with reasonable P/C size increases. Going to a 105mm P/C gets you displacement but unless you are going to have LN nickies there will always be a heat concern. A 2.3 with the right parts can make a very good running engine. Unless the engine you get is built by someone with talent like Raby, it is difficult for most builders to push it beyond the 2.3 with out issues. So even at the 2056 level a build with a good cam and big alve heads can make a really fun package for a reasonable price. At 2.3 it starts top get expensive but very fun. Without details it is hard to tell if the $8k is a good deal. But you can certainly do it for less. |
thelogo |
Jun 14 2018, 08:11 AM
Im switching to a /6 So the big 4 is available, 2366 with webbers an about 5k miles on it Total package for 8k $ But must do local pickup in sgv $8k for a VW engine? Looks like price gouging to me. Tell that to raby A complete plug and play setup , for less then it cost to build Doesn't seem like gouging to me but if you want performance then that cost $ Were not talking stock 16oo here vw engine |
thelogo |
Jun 14 2018, 08:15 AM
Without detains it is hard to tell if the $8k is a good deal. But you can certainly do it for less. [/quote] The devil is in the details i agree (IMG:style_emoticons/default/pray.gif) Attached thumbnail(s) |
jmitro |
Jun 14 2018, 11:36 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
A complete plug and play setup , for less then it cost to build Doesn't seem like gouging to me but if you want performance then that cost $ Were not talking stock 16oo here vw engine agreed. I would certainly be very interested if I didn't already have an engine to put in |
type2man |
Jun 14 2018, 06:43 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
A 2.3 with the right parts can make a very good running engine. Unless the engine you get is built by someone with talent like Raby, it is difficult for most builders to push it beyond the 2.3 with out issues. Ouch, I think you just offended a few hundred talented engine builders around the country. |
Mblizzard |
Jun 14 2018, 07:33 PM
A 2.3 with the right parts can make a very good running engine. Unless the engine you get is built by someone with talent like Raby, it is difficult for most builders to push it beyond the 2.3 with out issues. Ouch, I think you just offended a few hundred talented engine builders around the country. Not the intent at all. There are a lot of talented engine builders that have that level of skill. Was not implying he was the only one that could do it but rather you need to go to one of those builders with that type of skill. |
bdstone914 |
Jun 16 2018, 08:03 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
[/quote] Not the intent at all. There are a lot of talented engine builders that have that level of skill. Was not implying he was the only one that could do it but rather you need to go to one of those builders with that type of skill. [/quote] (IMG:style_emoticons/default/agree.gif) With any engine the first concern I would have is who build the engine and exactly what did they put into it alone with their skill and knowledge level. Many ways to make mistakes or cut corners and end up with a pile of scrap. As an example I bought a 1.7 engine rebuilt by an aircraft mechanic. Grease and dirt on the heads made me suspicious. Compression was 100 PSI on all cylinders. CR was 6.5 to 1. Heads needed $500 in work to make them right. Hope everything in the bottom end was done right. Bruce |
bdstone914 |
Jun 16 2018, 08:06 AM
Im switching to a /6 So the big 4 is available, 2366 with webbers an about 5k miles on it Total package for 8k $ But must do local pickup in sgv $8k for a VW engine? Looks like price gouging to me. I think that calling in a VW engine is what is misleading people. Even they can get silly expensive. I remember going to FAT Performance ( before they were sold to Rimco ) and seeing build tickets on Type IV engines in the $10K to $14K range. |
type2man |
Jun 16 2018, 04:22 PM
Im switching to a /6 So the big 4 is available, 2366 with webbers an about 5k miles on it Total package for 8k $ But must do local pickup in sgv $8k for a VW engine? Looks like price gouging to me. I think that calling in a VW engine is what is misleading people. Even they can get silly expensive. I remember going to FAT Performance ( before they were sold to Rimco ) and seeing build tickets on Type IV engines in the $10K to $14K range. Yep, I have a 2733 built by Fat Performance and the build sheet in 1982 was 10k for a complete turnkey engine with 48 Webers. |
thelogo |
Jun 16 2018, 09:04 PM
Im switching to a /6 So the big 4 is available, 2366 with webbers an about 5k miles on it Total package for 8k $ But must do local pickup in sgv $8k for a VW engine? Looks like price gouging to me. I think that calling in a VW engine is what is misleading people. Even they can get silly expensive. I remember going to FAT Performance ( before they were sold to Rimco ) and seeing build tickets on Type IV engines in the $10K to $14K range. Yep, I have a 2733 built by Fat Performance and the build sheet in 1982 was 10k for a complete turnkey engine with 48 Webers. A 2733 ??? Is that supposed to be a 7 ? Wow |
rad23racer |
Jun 18 2018, 09:23 AM
Newbie Group: Members Posts: 17 Joined: 28-May 17 From: Corona, CA Member No.: 21,137 Region Association: Southern California |
I have a 2056 built by FAT last year that still hasn't gone in my car with a trans from Rancho. The motor dyno'd at 142 hp. New Weber carbs and ignition. Basically went through the catalog and did everything they offer to make it reliable. Found rust in the body I have and have kind of lost interest. I think I have $11,500 in the engine and another $2500 in the trans. If you are interested, let me know and we can talk price.
type2man |
Jun 18 2018, 07:50 PM
Im switching to a /6 So the big 4 is available, 2366 with webbers an about 5k miles on it Total package for 8k $ But must do local pickup in sgv $8k for a VW engine? Looks like price gouging to me. I think that calling in a VW engine is what is misleading people. Even they can get silly expensive. I remember going to FAT Performance ( before they were sold to Rimco ) and seeing build tickets on Type IV engines in the $10K to $14K range. Yep, I have a 2733 built by Fat Performance and the build sheet in 1982 was 10k for a complete turnkey engine with 48 Webers. A 2733 ??? Is that supposed to be a 7 ? Wow Yes, 82x103 |
thelogo |
Jun 18 2018, 09:43 PM
Hi bob
Engine is still in the car and being driven every sunday And religiously maintained, i have all recipes for oil changes and valve adjustments All the info i have i posted below Which is all the info i saw before i bought it about 15 months ago . I got it from a known and reputable world member here So i was not really concerned with dynos and blueprints But i did contact european motorworks to get some back round on it and they confirmed the details and expense of the build . (IMG:style_emoticons/default/beerchug.gif) Any other ? I will be happy to answer if i know Attached thumbnail(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 05:27 AM |
