oil pressure, oil pressure |
TonyA |
Jun 13 2018, 03:25 PM
Nachmal Group: Members Posts: 460 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
My question is how can I check the oil pressure.
First some background and history. I have 914 1974 with a 2.0 fuel injected engine. PO said that the car sat for 15 years. When i got it first i changed out the fuel pump, new gas lines redid the gas tank, changed the oil, inspected with a camera through each spark plug. All looked great! Put some mystery oil in each cylinder and turned a little each day for about a week very carefully. Adjusted the valves new plugs and buttoned up. Installed fresh gas and started the car. Ran great blew out some mouse poison and some smoke of course. I did not run it to long because i would like to know if the oil pressure is ok. |
worn |
Jun 13 2018, 04:26 PM
can't remember Group: Members Posts: 3,150 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
My question is how can I check the oil pressure. First some background and history. I have 914 1974 with a 2.0 fuel injected engine. PO said that the car sat for 15 years. When i got it first i changed out the fuel pump, new gas lines redid the gas tank, changed the oil, inspected with a camera through each spark plug. All looked great! Put some mystery oil in each cylinder and turned a little each day for about a week very carefully. Adjusted the valves new plugs and buttoned up. Installed fresh gas and started the car. Ran great blew out some mouse poison and some smoke of course. I did not run it to long because i would like to know if the oil pressure is ok. I would say if you got that far, you can go the rest of the way. You can add an oil pressure gauge at the place where the idiot light switch is installed. A manual is in your future anyway, and that will show you where the parts are. If the idiot light goes on with ignition before starting, it probably works. |
Lo-Fi Version | Time is now: 5th May 2024 - 08:05 AM |
