Engine swap or "just" replace the clutch? Keen to see what you woudl do here.... |
Tdskip |
Jun 13 2018, 03:50 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Pushing aside the new one for a bit, I am chomping at the bit to get the "turbo" car into daily service. Only blocking issue at this point to using as a daily is the clutch is slipping badly. Not an adjustment issue, the clutch us just tired.
But here is the thing, I have a low mile rebuilt 2.0L with dual carbs that I picked up last weekend that is ready to be put into a car. Apparently it isn't much more work to just drop the whole engine than just dropping the transmission so why not, which has me thinking... Pro of the engine swap is that it is ready to go and a 2.0l wthat would be going whereas the engine in the car currently is a 1.8 that seems OK but had boost on it at some point. Not sure how well that was done. Not sure if the engine was built to handle boost etc... With the 1.8l out of the car (having been replaced by the 2.0l) I can better access what is going on with it and how healthy it is. Con of the engine swap is that the current engine runs and seems healthy, so why mess with something you don't have to. Exhaust on it is funky, but it is all connected, so if I put the 2.0l in I can't re-use the existing exhaust so I've got to fab something up which is tine and money and delay on driving. I've not heard the 2.0l run, story and documentation on it all checks out but it could still be a paperweight for all I really know. Give me a dope slap here if any of this is glaringly stupid or I am missing obvious things. What would you do? |
jcd914 |
Jun 13 2018, 04:00 PM
Just put the clutch in it and drive the 1.8 for awhile.
You will be able to better assess the condition of the 1.8, having driven it some. Also the 2.0 will not just go in, plug and play. They never do, there will be something you are not counting on that will stop you or add hours or days to the swap. Just my 2 cents. Jim |
914werke |
Jun 13 2018, 04:04 PM
"I got blisters on me fingers" Group: Members Posts: 10,004 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
What you dont mention is how much $'s to throw at this little project.
If it was a daily driver Id spend just wat was necessary to keep it running & (relatively) reliable. No budget (= no $); steal the good clutch off the ready to go 2.0L & go. Small budget; replace the questionable exhaust with an OE (or better) 2.0L exhaust & muffler, if your a little more ambitious ..go 1911. What this allows is you to verify the 2.0L at your convenience & or improve it ala 2056 + whatever else it is found to need. |
Tdskip |
Jun 13 2018, 04:53 PM
Thanks gentlemen - dealing with the Devil I know has less moving parts, good point.
The only cost with what you've suggested would be the clutch alignment too for like $9 this way. I'll put the 2.0l aside for the '74 roller and wait until I have the time and budget to do that right. Thanks for the dope slap and wise counsel. |
GeorgeRud |
Jun 13 2018, 05:03 PM
Does California require emission control inspection on the 1.8 (I assume it’s a ‘74)? That would put a damper on the carbed engine, but I thought they didn’t go back beyond 1976.
Tdskip |
Jun 13 2018, 05:49 PM
Does California require emission control inspection on the 1.8 (I assume it’s a ‘74)? That would put a damper on the carbed engine, but I thought they didn’t go back beyond 1976. Hi George-that's a good consideration but fortunately because these cars are older than 1975 I can do whatever I want with them. Thank you for asking the question however, appreciate you taking a look. |
type2man |
Jun 13 2018, 06:02 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
If you have some sort of warranty on the 2.0 slap it in and see if it works. This way you can take it back if it's a paperweight. if not just do the clutch and keep ripping on the 1.8
Tdskip |
Jun 13 2018, 07:03 PM
Thanks.
Going to start a new thread to get some coaching on what I should do while I am in there.... |
Lo-Fi Version | Time is now: 26th April 2024 - 04:43 AM |
