Engine swap or "just" replace the clutch? Keen to see what you woudl do here.... |
Tdskip |
Jun 13 2018, 03:50 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Pushing aside the new one for a bit, I am chomping at the bit to get the "turbo" car into daily service. Only blocking issue at this point to using as a daily is the clutch is slipping badly. Not an adjustment issue, the clutch us just tired.
But here is the thing, I have a low mile rebuilt 2.0L with dual carbs that I picked up last weekend that is ready to be put into a car. Apparently it isn't much more work to just drop the whole engine than just dropping the transmission so why not, which has me thinking... Pro of the engine swap is that it is ready to go and a 2.0l wthat would be going whereas the engine in the car currently is a 1.8 that seems OK but had boost on it at some point. Not sure how well that was done. Not sure if the engine was built to handle boost etc... With the 1.8l out of the car (having been replaced by the 2.0l) I can better access what is going on with it and how healthy it is. Con of the engine swap is that the current engine runs and seems healthy, so why mess with something you don't have to. Exhaust on it is funky, but it is all connected, so if I put the 2.0l in I can't re-use the existing exhaust so I've got to fab something up which is tine and money and delay on driving. I've not heard the 2.0l run, story and documentation on it all checks out but it could still be a paperweight for all I really know. Give me a dope slap here if any of this is glaringly stupid or I am missing obvious things. What would you do? |
GeorgeRud |
Jun 13 2018, 05:03 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Does California require emission control inspection on the 1.8 (I assume it’s a ‘74)? That would put a damper on the carbed engine, but I thought they didn’t go back beyond 1976.
Tdskip |
Jun 13 2018, 05:49 PM
Does California require emission control inspection on the 1.8 (I assume it’s a ‘74)? That would put a damper on the carbed engine, but I thought they didn’t go back beyond 1976. Hi George-that's a good consideration but fortunately because these cars are older than 1975 I can do whatever I want with them. Thank you for asking the question however, appreciate you taking a look. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:28 AM |
