Horn slip ring contact broken, Any ideas how to repair? |
PDXMike |
Jun 13 2018, 09:48 PM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
The spring contact on the direction indicator switch that is supposed to make contact with the horn contact ring in the steering wheel is broken. Has anyone managed to repair this?
I was thinking I could bend up a replacement piece of spring steel or brass, but I'm not sure how to attach it. I'd rather not have to drill out all the rivets. Maybe I could thread the center of the existing rivet and screw another piece on top. then I could solder the new piece to the existing one. |
Tjmrfe |
Jun 15 2018, 06:34 AM
NON IMPEDING RATIONE COGITATIONIS Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
The spring contact on the direction indicator switch that is supposed to make contact with the horn contact ring in the steering wheel is broken. Has anyone managed to repair this? I was thinking I could bend up a replacement piece of spring steel or brass, but I'm not sure how to attach it. I'd rather not have to drill out all the rivets. Maybe I could thread the center of the existing rivet and screw another piece on top. then I could solder the new piece to the existing one. Boy oh boy....I had same issue, spent way more time trying to “fix”this...the space is so unforgiving that I ended up just buying a replacement turn stalk assembly it was the best $30.00 I could’ve spent. I’m usually a patient guy too. Good luck, |
914Sixer |
Jun 15 2018, 07:22 AM
914 Guru Group: Members Posts: 8,869 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Buy a new one
PDXMike |
Jun 15 2018, 10:51 AM
QUOTE Boy oh boy....I had same issue, spent way more time trying to “fix”this...the space is so unforgiving that I ended up just buying a replacement turn stalk assembly it was the best $30.00 I could’ve spent. I’m usually a patient guy too. Good luck, At first I only saw the original Porsche part for $325. A little more digging and I now see the $45 repro. A new part it is! Thanks for the help. |
Lo-Fi Version | Time is now: 25th April 2024 - 03:43 AM |
